2001 Suzuki 115 4 stroke ??
kittycat
I have a code 2-2 coming on in my 2001, 115 Hp 4 stroke Suzuki , we have changed out many parts to try to find the problem with no resolve, items changed , computer , throttle body , map sensor , air valve , plugs , valves adjusted , timing checked. compression checked , leak down test , the only way the motor will stay running is to adjust out the air mixture screw on the throttle body.
kittycat
CTP switch throttle position switch ,also listed as air intake system
lakensea
Did you use a factory service manual to properly diagnose all those parts as failed, or did you just throw them at the engine hoping one was bad? That's a lot of expensive parts to just be guessing. Some of them have nothing to do with a 2-2 code.
That is not a mixture screw - it is a bypass screw - did you put the IAC in fixed duty cycle to properly adjust it?
kittycat
LOL , a friend of mine owns a suzuki dealership so all the parts were supplied from them . and they are doing the repair , its at a stand still currently and yes they did all the things you asked about also . sorry for the wrong term on the screw , that why its there since iam clueless other than spark plug replacement.
