2001 Motorguide 752V Magnum
pjhageman
1.) Just discovered corrosion under the paint at the back of the lower unit, in front of the (removed) prop. How does this happen, and, is there a cathodic zink available to prevent this corrosion?
2.) Can someone point me to a maintenance manual for this trolling motor? I would like to open the lower unit, inspect, and replace anything necessary - especially the prop shaft seal.
3.) Any suggestions on what particularly to look for?
Any help appreciated.
Phil
5150abf
Re: 2001 Motorguide 752V Magnum
If fit still works as it should I wouldn't take it apart, the old addage, if it ain't broke... besides if it leaked it would short out immediately.
Aluminum is like copper, the corrosion actually forms a protective barrier, that is why you never see aluminum corrode all the way through like steel unless it is electrolosis.
Don't know this for sure but I would be suprised if the outer casing was charged, it is more likely that the paint just didn't stick, common with aluminum.
Sand it down around the corroded area going beyond it to good paint and hit it with some etching primer and repaint and it will be good for another 8 years.
I take everything apart but I would never try a troller unless it didn't work, then you have nothing to lose, price a new one and see if you still want to take it apart.
pjhageman
Thanks, Irish (presume that's Notre Dame - I went to Illinois for a while). Appreciate the advice about the etching primer. Didn't know there was such a thing. Built Motorguide tough - hard to believe it still works after eight years, the last three years sitting in the garage while I was in Europe.
