2001 Mercury Outboard 2 stroke starter issue
Crosbyman
make certain battery is fully charged and apply a touch of lubricant on the shaft
Charge the battery.-----Have battery load tested.----Inspect battery cables.----Check connections are tight and +( red ) goes to + terminal.-----Take starter apart for inspection / cleaning / new brushes / ohm check on armature.-----Make sure battery is hooked up correctly.-----No $$$ beer tokens spent do check all that.----Horse power and model # of your motor ??
I can not touch your motor !----Some simple checking on your part needs to be done.
See post #3-----And I think it should be simple to find the issue.
Chris1956
I presume the starter is spinning in the correct direction? Doublecheck the battery cables to make sure they are not reversed.
