gydatree
Thread starter- Joined
- Jul 3, 2016
- 33
Hi. I have learned a lot reading these forums over the years, and I am at wits end trying to track down whats causing my 90 hp 2 stroke on my 25 ft pontoon to bog, so I figured I'd post and see what we get from the pros.
So, I bought this boat and motor as a project, tore down the boat to the toons and rebuilt/reupholstered everything. It definitely sat out of the water for at least a year before I got it, and I dont think it got all that much use before that.
When I got it, it would crank and run, though like crap, it did crank and run out of the water. When we were close to finishing rebuilding the boat itself we started to look at the motor. First, I replaced the fuel line with bulb and in line filter, got it to start up, but still sounded bad, so i rebuilt the fuel pump and carburetors and added new plugs. Put it in the water and though it had a rough idle and low speed it got up and ran beautifully across the lake for maybe 4 or 5 trips over maybe 3 weeks.
Not sure if its coincidentally or not, but one day we put ethanol gas in it, maybe 9 people on board and headed out. It started missing lightly on the way out when we would hit waves, and on the way back in it wouldn barely go ver idle speed without bogging. I then rebuilt the carbs and replaced sparks again and secured all fuel line connections. Put it back in this weekend, and at first it bogged when i gave it any gas, but after very very slowly accelerating I got it up to about 15 mph, ran like a dream for a bit, then bog. After re priming I can get it going again and do the same thing.
However, after being out for a few hours, it begins to not want to go at all. I rode for a while with my hand on the bulb and most of the time when it bogged it lost pressure, and with some pumping right when it happens I can keep it going and re prime the bulb and so on and so on.
The battery seems to maintain strong voltage, so I dont think its the stator. I have also replaced the starter, cleaned all electrical connections in the motor (always starts right up and runs no problem), added new battery cables, and changed the gear lube with new seal gaskets. Ive got the carb screws a little over 1 1/2 turns out evenly, no smoke really ever comes from the motor, timing sounds good when it is running.
So, the only ideas I have are:
*When I rebuilt the fuel pump, I didnt add the rubber circular gaskets in the kit as they were not on it when I pulled it out; could it be an ethanol issue where just those plastic gaskets cannot handle the ethanol alone? Would the bulb lose pressure if so?
*The long gold needles in the carbs that run all the way through them permanently and dont move, not the float needle that hangs from the float, leans to the side and touches the inner wall of the nozzle coming up in the middle of the carb on two of them, and it looks like the top one is headed that way. Again, not the nozzle that the float attaches to. It is in the middle of the carb. Could this be an issue? Mercury said it is, most mechanics seem to think its ok, as I see them for sale like that.
* Pin hole leak in the fuel pump diaphram? when I secured all fuel lines, I pressure tested through the pump with it mounted and it was very air tight. The plugs did seem to have oil on then, the old ones had a lot (1st set i put on). I was thinking it was due to having to drive so slow so much) and the bottom one did seem to have more. After running all plugs are hot, letting me know its hitting all cylinders.
* Oil fuel mixture? I could try to bypass the oil reservoir and pre mix the fuel?
*Worst case: Bad gssket in the powerhead? It does seem to let out excessive fuel, it is a two stroke, but it does seem to let out a good bit after running.
Also, when the motor is off it is hard to get the bulb primed if it isnt already. I can see it go through the filter, and seems to not want to make it all the way through it. however, once it is running it will usually prime up.
Any suggestions would be greatly appreciated!
