2001 mercruiser 5.0 gm temp sender
andrewcoon
Hi guys where is the temp sender on the model in the title? I need to ground it and test the gauge and horn thanks guys
Fun Times
Hi there, Typically you should be able to find them on the sides of the thermostat housing. Now on some of the early models, you may find the sender close to the thermostat housing but mounted on the "intake manifold". You may have to remove a hose to gain easier access to them. The sensor should have a yellow and black wire going into it and you just unplug it while the other sender will have a tan wire going to it. See and click on item part numbers 8 & 16 for photos. Hope this helps, good luck.:)
http://www.mercruiserparts.com/Show...desc=Wiring+Harness+And+Electrical+Components
andrewcoon
You are awesome! But I do have another issue, I tried grounding these and nothing does it Have To be Running?
Nope,.... Just the key "On",.... With the key "On', the gauge should peg to Hot when groundin' the sender, 'n the alarm should ring when groundin' the switch,...
