2001 Mercruiser 4.3 Knocking
EndlessCruiser
any ideas why it would be knocking so hard.
I was running about 3700rpms on my twin 4.3 Regal 2660. had been running great... wife noticed a wierd noise. I slowed down and engine turned off.. after restart it started vibrating so kept it off until we got to the docks... after I started it again in almost didn't want to start and noticed a slight knock... today I went back to the slip 4 days later and here is the video... a pretty loud noticeable knock.
link
Oil pressure is at 40psi at idle.
it sounds like a bottom end knock.. but not too familiar with this engine.
thoughts...??
thanks in advance...
achris
More fish than mountain goat
That's a bottom end knock, so shut the damn thing down! You're doing more damage just running it!
Pull the spark plugs and do a compression test, that will tell you which piston has a hole in it!
Chris......
Bt Doctur
Have to agree with Chris. Does have that rythmic tic of a busted /loose rocker arm too. The deep rumbling in the background, noise or exaust in water
Ayuh,.... Welcome Aboard,..... That motor has to come outa the boat, for repairs,.....
I'm guessin' it'll take a new long block, or a bobtail motor to fix that knock,....
