2001 Johnson Faststrike 115 Throttle sticking
GrumpyToledo
Hello
Thought throttle cable may have been hanging up in control box, or at throttle connect, these seem ok now that at home on muffs. Friend of mine gave me this boat after getting a new one, it sat up for 3 yrs, I blew crap out of 1 carb already that was keeping it from getting up or idling and after a few "no problem" trips, the throttle hung up while up and moving pretty fast. The boat road gets real short when this happens. The kill switch worked and the next time it did it, (not as fast), the key killed it also. I rebuilt a complete 1989 evinrude 40 powerhead a few yrs back w a seloc book and these boards, that is still running awesome today, ty, but this 115 is more intimidating. I can follow directions. A runaway motor is scary as hell, and my Son was with me. Any input much appreciated, thanks.
Chris1956
Honorary Supreme Mariner
That motor probably has a spring powered spark advance return mechanism. They can get dirty and stick open. Look next to the flywheel cover and have someone advance the throttle (motor off), and see what moves. Now have them retard the throttle and use a finger to move it manually and see if it is sticky.
GrumpyToledo
Ty for a reply, Ok, last night, sprayed WD-40 thru Advance mechanism plate in there, moving back and forth now. I was watching that area and can't say it was coming all the way back for sure, but it was not staying all the way forward, I would have caught that. If it stayed say 50% forward, could it cause the RPMs to try and max out like that? Also, I don't want to break that flywheel cover but can I lube that advance base easier if I remove the 3 phillips screwed black cicular top cover? Wanna make sure if it is dirty, I get to it. Also, dirty fuel came out lower port side carb when took breather off, think it got gunked up again.
jakedaawg
So, a Maumee river runner? Ha.
Well, if you got junk out of one carb probably should do them all. Also the throttle bodies.
With these motors you really need a oem manual and some know how to get up under the flywheel. You also need a couple special tools to do the link and synch....it's technical but not terribly difficult if that makes sense.
GrumpyToledo
Rebuilding carbs, putting a hot foot and 2 new cables on it, will bring to lake and run w cow off so I can starve it if it sticks again.
