sammy29926
Thread starter- Joined
- Jun 24, 2008
- 47
hi Everybody,
I have a2001 larson With johnson 150 on it. Whe i purchased the boat Gauges did not operate and i send the m to faria for warranty work. I recieved them and after i hook everything up... Which i am %100 sure everthing hooked right.. ( i took pics of the wires how where they connect to gauges, Took notes ect.) I crank the motor up.. it started right away my Trim, Tach, Volt meter works now except the fuel gauge which i believe it tis the sender.. But then i Turn the ign switch off.. Engine keeps runing.. Power to my gauges goes off but motor keeps runing .. I ended up using the mergency shut off switch( I am not sure if it is the right term .. ) which is on the remote control panel with w red cord attached to it. My question is what might have caused this? Ign. Switch used to work fine before i took the gauges out... I am open to any advise to help me pin point the problem.
Thank you
Sammy
Thank you
Sammy
