2001 Johnson 90hp V4 rebuild specs
MtyMidget
I have a 2001 Johnson 90 HP V4 that I got on a pontoon boat that had a bad piston. I took it apart, Repaired the Cylinder and got the new parts. What I need help with is the Torque specs to put it back together. I need Con Rod and head bolt torque specs please or where to get them.
Thank you,
Marvin :confused:
Rod bolts are 370 INCH LBS.------Rod bolts are not a " simple torque them up item "-----You need to line up the caps carefully.----
Faztbullet
Torque in 3 steps...10ft.lbs, 20ft.lbs, 30ft lbs and use new rod bolts.
MtyMidget
I did get new rod and bolts...Thank you....Do you know the head bolt torque?
