I've got great running 70HP with one problem I and others haven't been able to fix. It starts fine, idles fine, give it throttle it gets up and runs strong.Now the problem, when I come off of plane and set the boat down to fish it will idle fine as long as I don't give it any throttle. When I advance the throttle it bods down and cuts off. The only way to get it on plane is to start it and get it full throttle, atfter doing this a couple of times it will take off and run fine. The next time I come off of plane it's the same thing. I've cleaned the cards twice, link and sync by a good mechanic, and decarbed it and added new plugs. Even swapped out power packs with no effect. I've been told it's the trigger but wouldn't that affect all operating ranges. I've also been told to rebuild the fuel pump( VRO is hooked up) I just don't know what to do or where to take it. I'm able to use it to fish but it is annoying.
