Hi guys
i have a maxicat 4.65 with 2 2001 johnson 2 cyl 2smokes on it.
The port engine is giving me brain damage.It does not produce power at wot throttle and will not rev past @2500 in gear.has good compression,swapped out the carbs from other perfect running engine with no effect.has new stator,power pack.sync n link is sweet.prime bulb stays solid and makes no difference if squeezing it while running,tank vents perectly and all fuel lines are new as is pump.VRO has been disconected and running premix.
this motor has been played with by 3 different shops and only gained about 300 revs at wot throttle for their efforts and my expense.
