rborden1974
Thread starter- Joined
- Jun 18, 2015
- 5
Good evening all,
I am kinda stumped when it comes to outboard problems. I thought I had a fuel problem with my motor, but I have changed all the fuel lines from tank to pump. I have replaced the primer bulb, And the anti-syphon valve on the tank. Also changed the pick up tube. This past weekend I put a new fuel pump on and it is still doing the same thing. It acts as if it is loading up and sometimes will plane out and run OK but with only a top speed of 50mph. ii also changed the plugs this weekend. They were pretty wet. Is it possible that I have a sparking problem instead? Last year the check engine light would come on and would have an alarm going off for like 5 seconds. The alarm would go off but the light would stay on. I changed all of my gauges so that isnt coming on now but is still running the same. Any information would be greatly appreciated.
Thank you in advance
Rich
Rich
