2001 Johnson 200 hp specification .
Looking4Fish
Hi
I am going to rebuild my 2001 Johnson 200Hp ( J200VXSIF) . After resleeve , bored all the cylinder,ordered complete rebuild kit ect...now I need help
about torq spec:
1.connecting rod bolts (max-min ft lb)
2.main crank bearing bolt(max -min ft lb)
3.upper crankcase head and bearing bolt (max-min ft lb)
4.bottom crankcase ***( max-min ft lb)
5.Intake manifold( cylinder to crankcase) (Max-Min ft lb) and the gasket pattern
6.Cylinderhead bolts ( max min ft lb) and the gasket pattern
I bought a lot of repair manual books, DVD , CD but can not find the torq spec.
Thank in advange
wilde1j
Re: 2001 Johnson 200 hp specification .
if you only had the OEM shop manual, you wouldn't be asking these questions. I don't have the book for your motor.
boobie
The only place I know where to find them is in the OMC Factory Service Manual. Sorry I don't have a manual on that mtr but maybe somebody on here does.
Faztbullet
Rod bolt 5/16.......................................42-44ft lbs
Rod bolt 3/8.........................................52-60 ft lbs
Main Bearing bolts................................26-30 ft lbs
Upper & lower end caps.........................72-96 inch lbs
Lower bearing retainer plate bolts..........96-120 inch lbs
Cylinder heads bolts ............................18-20 ft lbs
(sequence should be cast on head)
Intake manifold bolts...........................96-120 inch lbs
(these are different lengths and some have sealer on them so take notes where removed)
