bottomline75
- Aug 26, 2009
- 8
Greetings...this is my first post. Having a devil of a problem with one of my engines on my Grady. Here's my problem:
I have twin 2001 Johnson 150's model VCXSIG. These are twins, same assembly line, etc. Everything is identical except the gear rotation on the feet. The beautiful thing about twins is that you have a guinea pig to interchange parts until you isolate the problem. I have Northstar fuel sensors. A few days ago, had what I thought was the fuel pump go on the port engine. I came to this conclusion because once the bowls are dry, you have to pump the bulb to keep it running, otherwise it dies. Also, the fuel sensor on the port engine registers 0.00 unless you pump the bulb. Both fuel pumps are VRO2 fuel/oil pumps with the oil intake capped. I premix. I also have two independent fuel tanks on separate lines that I can feed to either or both engines.
Well, I ordered the diaphragm overhaul kit for the pump. Rebuilt it and reinstalled. Engine will still only run so long as I pump the bulb. So, I took the rebuilt pump and put it on the other engine just to check its function. It pumps fuel fine to the strbrd engine, no problems. Put new fuel filter screens (at the intake) on both engines. Put new fuel/water separators on both engines' lines. Checked all lines and cleaned them, no leaks or clogs. Just to double check the bulb on the bad engine, I disconnected the one from the good engine and hooked it up to the bad one and vice versa. Same thing, bad engine still bad, good engine still good. I also disconnected the fuel sensor in case it was clogged, still the same thing. Both tanks' anti-siphon valves are clear, and besides, the good engine pumps fine from either tank. I also checked and cleaned the vapor bowl assembly.
I have also noticed that the bad engine tends to idle at a higher rate than it did before this problem ~ around 1800 on the muffs. I know it is supposed to be slower in the water, but it has always idled around 1200 or so on the muffs prior to this, so it is definitely different. I have not had the boat in the water in almost a year, but run the engines religiously on the muffs once a week.
I am stumped. Anyone have any ideas?
Mike
Mike
