2001 Johnson 15 HP - General Questions
T225Grady
I recently acquired a 2001 15 hp J15RVSIC outboard. I have a few questions foroutboard GODS.
1. Is there a way to convert this engine to an electric start? If so can you guys help me out with a parts list?
2. Any way to add a regulator / rectifier to charge a battery? I assume I would need a lighting coil to supply an AC to the recifier. Again parts list would be greatly appreciated.
There appears to be some spots to bolt on (see pic)
Thanks
Honorary Supreme Mariner
Yes , many left the factory with electric start and battery charging bits.-----Look it up , part # are available online.------evinrudeparts.ca ----Is but one such place.
oldboat1
I think you bought the wrong motor for your wants and needs. Sell it and start over with some money in your jeans.
Best , as in most economical way is to keep your eyes out for a donor motor.----1993 and newer model 9.9 and 15 HP 2 strokes.-----It also depends on whether you want tiller electric start or going to a remote electric start set--up.-----E-bay might help out here.
bbbuuuggg0
I just did this same conversion this weekend. Took me about 2 hours. Found all parts on eBay for $275. With a bunch of stuff I didn’t need, since mine is a tiller and parts are for remote. Flywheel, starter, solenoid, magneto with lighting coil and a push button. That’s it. If you don’t want it to charge then just flywheel and starter and solenoid. I didn’t put in electric choke or primer. No need
