2001 Ficht Ram v4 75Hp correct replacement EMM
dstanden
Hi everyone, I purchased a 2001 Evinrude Ficht Ram very cheap knowing it had a blown 586518 EMM. Fault # 37 then series of 8's fatality. No ignition. I've been hunting around for a replacement on e-bay and reading a lot of forum posts and seem to be getting conflicting information. The DFI technologies website shows 586484 as a possible upgrade/ replacement but most I've seen are all off v6's. I've also seen 586724 EMM's for sale starting they will work on the 2001 V4's. I do have a registered copy of EVdiag and can perform an EMM replacement.
Question 1: would the newer model 586724 EMM's be more reliable then replacing my EMM with an original 586518?
Question 2: Can the 586724 be used on a 2001 V4?
There seem to be a lot more 586724's available out there and a bit cheaper than the 586518's.
I spoke with MarineComputerSupply and he told me the series of 8's was not repairable and he didn't currently have another 586518 as a core to repair for me. That's why I'm hunting down different options.
Any advise would be greatly appreciated and thanks to everyone in advance.
Faztbullet
This difference is the injectors as they changed in later 2001/02 and they added exhaust pressure sensor. The OEM number does not cross reference over
Part Lookup
OEM Part Number
Part Details
Part Number0586518
OMC[SUP]®[/SUP] SYSTEMATCHED[SUP]tm[/SUP] Part#No Cross Reference Found
Supersession
DescriptionEMM AY (QIPL)
Pack Quantity1
Weight/Dimension8.24 lbs / 12.75 in length X 11.50 in width X 4.25 in height
3.74 kg / 32.39 cm length X 29.21 cm width X 10.80 cm height
dstanden
Thanks for the reply Faztbullet. Guess I'll keep looking for the an original 586518 EMM
Faztbullet
Call Jays Block Shop in Sparta ,Tn an ask for Jason. Tell him Alan sent ya. He has a lot of dealer/rep connection and might can help ya find one.
