2001 Evinrude/Suzuki 70hp Turning Engine Off and Back On Clears Problem Temporarily
vettnut
Yesterday my 2001 Evinrude/Suzuki 70hp Four Stroke Fuel Injected Outboard ran fine till it was time to head back.
Once up to top speed the engine began to slow down and I'd be down to 6 mph. If I shut the engine off, it would run fine till I was at top speed then the same thing happened each time. The engine was Not cutting out or spitting at all. It seems like something in the engine controls is slowing down the engine.
I just had the fuel injectors thouroughly cleaned and the engine and the water/fuel seperator filters changed with new plugs with a new squeeze bulb and hose. All the fuel in the tank was removed and filled with fresh fuel.
What would reset by shutting of the engine and then come back??
Sensor?
I spoke to my mechanic who owns and runs a Suzuki and he has the same problem and has never found the solution. The difference is, he says once he shuts off the engine it go aways. Mine did not go away. Mine kept coming back, everytime. I tried sqeezing the new fuel bulb. Restarting engine and same thing happened again and again.
Anyone else have any ideas?
Thanks
daselbee
Yes...well maybe.....
You probably have a code stored in the EMM for this problem. Not sure. But you need to get that code (or codes) that are stored to start the debugging process.
The tach check engine light will blink the codes if you turn key to on and watch...count the blinks.
What is the tach RPM when this problem is occurring? Not boat speed...tach RPM.
If no codes, then you could start by putting a fuel pressure gauge on the fuel rail, or maybe the fuel hose that directly supplies the fuel rail.
You must maintain 40 psi fuel pressure, and it would be nice to know whether fuel pressure was dropping off when you have your shut down.
Fuel pressure dropping off will NOT store a code.
Another thing you can do is get a temp gun and read the engine head temps when it is shutting down like you describe.
Read the thermostat housing, read down into the spark plug holes, deep are you can, in the same spot for each cylinder.
The thermo housing should be 142*F. You will get varied readings from the spark plug holes, but post them anyway.
They will probably be in the 160* range.
There are two temp sensors. One is on the exhaust manifold...silver chrome with a wire coming out....measure the temp right there.
The other temp sensor is behind the plastic EMM holder and cannot be easily read with the temp gun.
If the temp sensors are causing this, then you definitely WILL have a code.
The thing that confuses me regarding this description is the fact that you say the engine is smooth running....no radical surging. When in safe mode, or rev limiter mode, the engine surges very noticeably.
This should get you started. Post back all results.
vettnut
The engine was running fine on the way back to the dock. Then the boat and motor started to slow down. The motor did not like having the throttle in the full throttle position. I brought the throttle back to the neutral position and begn increaing throttle to see where it stopped increasing. I did not Note where the rpm was at. Top speed of this boat was just over 30mph yesterday.
Yes, when running the throttle control Only the engine will cap out at 2800rpm and begin surging up and down when the rev limiter is hit.
Why does shutting off the engine clear this problem, only to come right back. The next time out I will note the rpm If this problem comes back.I'll check my electrical connections.
Sensor? Code?
There is an open brass vacuum port designed for a hose in the front of the motor in the center. There is no hose or any other nipple to run to. I believe it should at least go to the throttle body. It is in the front of the motor in the center. Does someone have a picture of a Suzuki/Evinrude 70 front with the shroud off of course, or at least look ands see if yours is the same?
Thanks
daselbee
That open brass fitting is supposed to be that way. It allows idle air in, which is metered by the IAC valve.
Do not plug that up in any fashion.
Yes....I figured it should be surging.....no fault will cause it to run smooth but slow....and 2500 is the magic RPM when SLOW kicks in.
You have an overheat, I think.
Either a bad sensor, or actual overheat. That's why I suggest the temp gun. Do it.
vettnut
If my check engine light is working correctly, There is nothing unusual. The 4 lights go through their respective checks, and then go out. On the water, none of my dash lights came on when I experienced this problem. About 1 month ago, the overtemp light and alarm came on. I shut off the engine and limped in with the kicker. I had a new water pump installed.
Yesterday the engine was cold, when this problem occured. The engine had been running for maybet 5 minutes, before full throttle.
Thanks
