Bought this motor very slightly used about 8 yrs ago.Put it on my 12' wide Alumnacraft jon.
Will plane off with mild load,aprox 325lbs people,some gear.With 2 adults and more gear it will not plane off.
The year after I bought it(it looks new)I went to OMC dealer,looked thru the parts books,and bought a new 8HP carb,and maybe a backing plate to adjust advance on timing,not sure on the plate,but all the different parts for the 8hp were bought.
I could tell very difference in low end power,maybe a little more rpm`s.Dissapointed to say the least.I did all he could find to do,still starts&runs smooth&great.
Any thing I missed in this up-grade?Dealer told me the 6/8hp series because of the small displacement had much less low end power than the 9.9/15 series,and I need the 9.9.I have a 15hp on a bigger boat,but want to use the 56lb motor on this boat because of sliding it down river bank,no triler.The 15 with electric start is closer to 80lbs.
I have not tried it out this new Solas 8x7 prop yet,but the stock prop on the 6/8hp is a OMC 8.5x9 pitch,is it likely I`m going to see a nice low end gain from this lower geared prop?
So to sum it up,did I miss something on the 6 to 8hp conversion,and will this prop help it plain,I realize I will loose 2-3mph on top end,assuming it planes out,and a boat that don`t plain will not do over 7mph anyway..
