2001 Crownline 266 ACC Switch
ontherox
After pulling out my instrument panel to replace my tachometer on a 2001 266 Crownline, I discovered my acc switch was then inoperative. I pulled the switch and found a wire had pulled from the wire spade still connected to the switch. One black wire is still connected to other side of switch. I have found a loose yellow wire with a wire spade still connected to the end but not a loose wire with a missing a wire spade still connected to acc switch. Not sure if the yellow belongs of the acc switch without a schematic. I've been unable to find a schematic on-line. Can anyone offer knowledge of the wire colors for the acc switch or a website with the schematic?
TSL812
Re: 2001 Crownline 266 ACC Switch
Do you have any accessories that haven't worked since you noticed it? If you bought the boat used it's possible the previous owner had something hooked to that they removed and pulled the wire out of the connector trying to un-plug it. You may have to try to trace that yellow wire and figure out where it runs. It could be left from something that has been removed as well.
burp
On the 266, there are either 1 or 2 ACC switches. One ACC switch is directly beside the trim tab switches, the other is up by the nav light switch and exhaust (captains call) switch. From the factory, there is a wire which brings power to the switch, then there is a wire pigtail which comes off the switch. The pigtail ends under the helm and is provided so that you can hook up whatever you want to power (GPS, VHF, etc). A yellow color wire should be a DC ground.
I'd look at my 266 but I won't be near it for a couple of weeks.
ontherox
Thank you both for the reply. The ACC switch did function until I pulled the instrument panel to replace the faulty tachometer. I must have pulled a wire loose. Wiring for the panel is pretty knarly and as careful as I was, still managed to pull a wire loose but didn't want to assume it went to the switch. I'm heading to Tablerock tonight and I'll try your advice this weekend. Thanks again.
EMS-Maryland
Re: 2001 Crownline 266 ACC and panel switchs
Delighted to find this Crownline forum.
We just bought a 2001 262CR with well-worn panel switches. Aside from the bilge and blower switches most of the remaining panel switches are a mystery. The panel switches are 5 on top, three on the bottom, and an AAC switch next to the trim tabs.
Can anyone help me ID these panel switches and tell me what the ACC switch is supposed to do? The first switch in the top row of 5 switches toggles up and down. Any info on the up and down positions would be greatly appreciated.
E.M.
dmjk
ontherox, i have a 2001crownline br 266 and need to replace the tach. I removed all the screws in the instrument panel but was unable to get the panel off. Did you have to remove the steering wheel to get the panel off?
ontherox
You do not remove the steering wheel. You'll remove the half dozen screws the secure the decorative face trim that all gauges and swithes are attached. Then you carefully work the face trim with gauges and switches attached only far enough to remove the nuts from the plastic bracket securing the tach to the trim. There are too many wires behind the cluster of gauges to completely remove the panel...unless you just want a challege putting all wires back. I chose not to have a nervous breakdown by leaving all wires attached and squeazing my hand in there with a small socket or wrench and only removing the wires from the tach.
When you iniitially try to remove the face trim with gauges, it is a little sticky by you'll see that you'll work it out a little at a time but it'll come out far enough to remove the gauge. Be sure you check for any other wires that could pull from terminals on other gauges and switches.
