2001 astro 4.3l vortec
jeremy888
hi, i hope someone can help me asap
i replace the intake on my 2001 astro 1950ss with a 4.3l vortec engine...i got everything back together and
need some info on how to time this thing
what is the correct procedure?
i removed the 1 spark plug to get the distributor in the correct position know i just need to know how to time it
thanks for any help
81 Checkmate
Re: 2001 astro 4.3l vortec
Bring no 1 up on COMPRESION stroke.... must be on COMPRESION stroke. Drop dist in with rotor pointing to number 1 on cap.
Back up.....Go ahead and pull the dist back out.... then place a mark on the body of the dist where No 1 plug wire is..... then take cap off.... now back to the motor... go back as first stated.... No 1 and so on
Now look and see if timming marks are lined up on the crank..... if so good......now drop dist in (Cap Off) with the rotor lined up with the mark on body. You want the rotor pointing in about the 5 oclock position. looking from the front to back of motor. Make sure it drops in all the way. If not take out and turn the oil pump shaft a bit. Try again.
Now snug up your hold down bolt...so you can still spin the dist....install cap back on, now place your wires back on cap starting with the number 1 that you marked and so on.....
Now try and start it. May have to move the dist a bit to get it to fire..
Final step set the timing.
Good Luck!
jeremy888
thanks for the reply..i have already done all that
i was just trying to find out about the final step ...i need to ground the purple with white strip wire..then what do i set the timing mark at?
