theonlyrobertson
Thread starter- Joined
- May 31, 2003
- 17
I have found bits and pieces of this topic in here but not a fully detailed one. I have factory manual on order, but would like to set this correct right away so any input will be helpful.<br /><br />I have initially set the carbs as follows:<br />Upper: 3/4 turn.<br />Middle/Lower: 1-1/2 turns.<br /><br />How do I fine tune these settings?<br /><br />I checked the cam/follower on the carb linkage. It has about .007" clearance.<br /><br />Question # 1.<br />I'm not sure the purpose of the white line is since the follower rotates freely on the shaft at idle. What is this for and how is it used?<br /><br />Question # 2.<br />Something I have not seen in the forum is a discussion of the idle screw (it has a big label on it). It has a white plastic cap on the head of the screw to make it easy to adjust with your fingers and it appears to move the lingage that connects to what I think is the timing advance under the flywheel. What is the proper adjustment for this?<br /><br />Thanks,<br /><br />Dale
