2001 60hp 4 stroke head bolt torgue spec?
MRJ82
I am trying to put together my 2001 60hp 4 stroke serial number 0T296762. Replaced a bad head gasket, and I am in need of the torgue specs for the 10 main head bolts, and the 5 small outside head bolts. Can anyone help me out here? Thanks
cyclops222
It can depend on the type of material the head gasket is made of. Also some gaskets need to be retightened after so many hours of running.
Did you check the flatness of the 2 surfaces ?
