I have a hard start issue with my 2001 Ficht 250. Last year around October the engine took 3-5 times to fire up but then it would be fine for the rest of the day and would run full rpm without misfire. The. It slowly got worst over a month and I needed my kicker to boost voltage for start-up. Althought it's fuel injection, I thought it was a cold temperature issues since it was my first winter with the engine. In February, i did my tune-up and changed the spark plugs (indexed and gapped), all fuel filters, leg oil, lubed all points and used fresh fuel. I had both batteries tested and one showed a fail althought it was a few months old. Replaced the battery and still the engine wouldn't start althought I had proper rpm as seen on the tacometer.
I decided to try to heat the engine by putting a 250w lamp inside and plugged it for 2 days. The engined fired right away amd therefore I put it back in the slip. Went back to the boat 4 days later with the lamp plugged and didn't fire up. I took the boat out and started reading the manual and did the following:
checked and cleaned all grounds and measured resistance
checked voltage drop on the year old starter
checked voltage at the starter soleinoid and the start assist circuit and changed the solenoid since I had a good spare and tested the spare
changed the cables from battery switch to engine
tested fuel pressure (30 psi) and holding
checked the lift pump and connection to crankcase
checked resistance of water temperature sensor and good
changed the AT sensor since it was slighly lower then specs
cleaned the exhaust pressure hose and checked diaphram
change stator as per dealer althought it didn't need to be changed since pushing 23v at cranking
dealer confirmed no codes
sent EMM and PDP to be overhauled for start assist circuit and apparently was fully functional on a 4cyl engine
chocked the intake manifold to see if it was running lean and no difference.
Connected booster pack directly on starter in case rpm was too low and no ignition.
TCP changed last year and dealer confirmed it's good
checked all ignition pack connection and cleaned one
tested all solenoid in the PCP
dealer changed the capacitor for an old one and still no go
not proud to say but I have to spray Starter Fluid to get it going. Once it runs for at least 15min, I can turn it off for max 5min and it will restart. Before it used to be the full day but it's getting worst every week. I do suspect a bad wire but I inspected most of them and no bulging and resistance is almost zero.
Moreover, if it's on the trailer under the sun when it's warm, it will start right away but not in the water. I also have a sticky throttle when slowing down and I have to keep it around 3000rpm until the boat slows down otherwise it will stay at 1000rpm. If so, I shut it off and restart it and then it will be fine.
Anyone has any ideas??? The dealer is stumped and most people I talked to.
