2001 150 Johnson
Billyloc
the motor starts fine, idles fine and get up to 46 hundred rpms then flutters. If u cross another wake and rock the boat it will run fine up to 52 Hundred. Sometimes it will be ok for a while then start dropping off again. Could that be a stater. We put a power pack on it and went thru fuel. Thanks for any help.
jakedaawg
Compression test, spark test, and try running on a different tank AND fuel hose. Report back observations.
