2001 Mercury EFI 115hp fourstroke.
No output from the charging system. Voltage at the battery is 12.08v. with or without the motor running. Used to see around 14v. up at the dash when all was well.
Checked the usual suspects first: loose or dirty posts or cables, tried running on one or the other and both batteries with the same results.
As the manual says, I checked the amp output after the voltage regulator/rectifier and get no output reading there.
From there it says to check the stator coil resistance using a special test harness, which I don't have. So no stator checking for me.
Any thoughts or suggestions other than taking it to my mechanic?
Does anyone know where to find a regulator/rectifier online?
When I search for one, nobody seems to stock one for the fourstroke motors.
Thanks, Scott
Thanks, Scott
