2001 115 hp Johnson
Kerr1e
Can someone send a photo of where battery cable connects to the engine? I just bought motor to put on boat
If it like my '98, the positive battery cable connects to the starter solenoid secondary winding, with several other red wires. The negative battery cable connects to a bolt in the block, very near the solenoid, also with several black wires.
Kerr1e
Thanks. I will look again. I can't easily see the solenoid
The starter solenoid should be directly under the starter.
Kerr1e
I found it. There was a plastic cover that had to be removed in order to find it.
