MikeinBoston
Thread starter- Joined
- Jul 7, 2003
- 1
This problem has plagued me since new. After the engine is good and warm, it won't start. For the problem to occur, it might take 40-50 minutes of running/trolling, or getting to the second or third fishing hole, etc., When you try to start after its warm/hot it just cranks and cranks - not any sputtering at all - then won't start until it sits for 20 minutes or so (often w/cover off). Water comes out the back of engine just fine. I've changed the spark plugs (Champion) - didn't fix. Changed the rubber fuel ball - nothing. Oil injected. ...dealer couldn't get the problem to do it for them, but that was in the first year. Now problem is consistent. But, when cold (or not run too much yet) -- it runs perfect. Even when the engine is "hot", I can usually put my hand on the top of the flywheel with no problem (so it doesn't seem too hot?).
<br />thanks, Mike.
