renegade15
Thread starter- Joined
- Mar 29, 2009
- 99
I have a little gear lube leaking from the prop shaft seal and am wondering if there are any pointers to replacing the seals when the bearing carrier does not appear to want to let loose easily. If I remove the two bolts in the photo attached, it should pull out and I can replace the seals then?
I was contemplating using a little heat around the seam and applying some pb blaster/penetrating oil. Any other suggestions are welcome!
