Groupergulper
Thread starter- Joined
- Aug 21, 2009
- 73
This is a used motor new to me, I hooked it up with all the factory wiring harnesses and controls. it starts right up, idles good, when i give it gas it bogs, if i pump the throttle it will rev up, once it revs up it will stay there, just cant get there without pumping the throttle, seems to do better when its warmed up. I have removed the vst and cleaned it and replaced the filter on the bottom of the pump, the vst was full of fuel . It has 32 psi which seems low. i checked and cleaned the strainer behind the regulator also, i installed new plugs, Im going to clean the o2 sensor after i post this, what about the throttle position sensor? im really not sure where to go with this? its all new gas (100 gallons), new fuel line from tank to engine, new oil tank with fresh oil. this is all still on the trailer,
Help
Help
