2000 Priemer 20' Pontoon corner
Bruce121
Hi. I have been looking for a stern port side pontoon corner for my 2001 Premier like the one pictured on the starboard side Do you have thoughts were I could find a match?
thank you,
Bruce121
ahicks
So you don't think everyone is ignoring you, I can't say as I've ever seen a permanent mounted ladder on the port (left) side of the boat.
MRS
you check with the dealer? If not maybe a sun tracker corner would work might have to modify a little but could be doable.
Go check them out and see if it might work for you. Good luck with your search.
Bruce121
Hi Ahicks,
The ladder is installed on the starboard pontoon so as a correction, I'm looking for a port stern corner.
MRS. I called the dealer and they weren't much help at all. Ive done a number of searches over the last 6-8 months. I can find smooth finished corners but nothing with a grove detail as I have on the other corners. I'll give sun tracker a try.
Thanks for your help
ahicks
I get what you are looking for. I've just never seen one installed on that side (port/left). That said, seems like many might be universal, able to work on either side.
