hi
the boat started going from normal 3/4 on the temp to redline and alarm going off. turn off the motor, turn it back on, its fine, so the egine isnt overheated. run it fast idle, 3-4000, no problem, but it in gear, go 10-15 mph, no problem, kick it up , does it again.
had the lower unit taken off, serviced, new impellor and housing, they say they checked the plastic tube that takes the water up, not sure the name of that, the shop said it wasnt cracked, that was a thought, that the exhaust may be getting into the cooling system and decreasing the flow enough that it doesnt get to the thermastat enough and the sensor goes off?????
took it out for a spin, did it again,
replaced the thermastat, it still does it.
the 4 hoses going to the thermasat housing, the one on the front left feels hot, the others didnt, not sure, which ones should be hot or not. That is all i know, any advice, anyone experience this ever
called merc, they had no idea, called 4 shops, they said start with what i did and go from there. at $80 hr, that will be expensive.
