2000 Mercruiser 4.3l Thunderbolt 5 ignition
Doctom
Ok
HOPEFULLY this will be the last update for this thread/problem.
Got to play with my boat tonight on the trailer with the muffs and hose. After doing a but ton of research to make sure that I was doing all things right, I redone the timing( it was a good bit off. I used the method posted in the adults only section. I read a step, then done it, read a step and done it, the whole way through), I also had to readjust the carburetor mixture and idle settings. After all of this I AM now getting the initial 10 at idle(about 650) and an additional 14 to 16(at 2k to 2500). I will attempt to put it in the water this weekend and if that happens, I will let you all know what happens.
Either way, THANK YOU ALL for your attention and help.
achris
More fish than mountain goat
Do you have a knock sensor attached to that distributor?
Doctom
Got to put the boat in the water today. It took throttle just fine in netural, however when I put it into gear it would only go to 2k RPM then back fire/cough through the carb, sputter and die. It would restart and idle fine untill I tried to give it throttle in gear and then it was just repeat 2k RPM, cough, sputter and die.
Thoughts Anyone??
achris
Check spark advance, and distributor and ignition module grounds.
