2000 johnson225 ho check engine light and buzzer coming on
BASSBOAT21
Banned
Factory setup 2000 model triton tr21---with johnson225 ho-----evrythings been fine---changed the fuel filter to a sea sense-unverial metal one see through with interchangable filters---went to river boat started off fdine then as rpms got to 3000-3300 the light came on and buzzer sounded---check all gauages water presuure was around 15 psi or better--- battery voltage fine--- at 13.5--14---all other lights or buzzers off----i stopped eased to location cut it off checked fuel connnections near fuel filter no leaks or off hoses or vaccums--filter full off fuel ---also only run non e10 gas----cranked back up later on headed to another location--running 3000-3500 rpm no lights or buzzers---get to locaton--fished then later evening leave to go to landing--hit the hot foot to get going goes to 2000 rpm ck engine light and buzzer again stay on it levels off into plane rpms increase to around 3000 everything goes off --i get to landing load up head home----nothing evr was wrong with it until i changed filter --checked to make sure i didnt put on backwards its on right----dont know if this had something to do with it or not--fuel restriction?---filter too small?---it has 3/8 end barbs---it has thge factoryplastic one on it---its located right next to the vro pump on engine---no restrictions in line and all line were rehooked up checked more then once---all wires are connected good---any help--
boobie
Re: 2000 johnson225 ho check engine light and buzzer coming on
Have you checked the anti-syphon valve on the fuel tank. Does the primer bulb want to go flat. ???
BASSBOAT21
Banned
have you checked the anti-syphon valve on the fuel tank. Does the primer bulb want to go flat. ???
primer bulb still hard---it has been replaced when doing regular maintance--oem one---- yes the syphon valve has been replaced during regular maintance---boat doesnt loose power i can still throttle up and go just scared too until i know whats causing the gk light and buzzer
boobie
Seeing it's a 2000 model built by OMC, you may just have a bad system check gauge. They did have probs. See if you can find a loaner just to plug in and try. I still keep one in my tool box just for that purpose.
BASSBOAT21
Banned
seeing it's a 2000 model built by omc, you may just have a bad system check gauge. They did have probs. See if you can find a loaner just to plug in and try. I still keep one in my tool box just for that purpose.
okay---so thats the complete rpm gauge unit---so maybe its a fluke it just happened after i changed fuel filter
boobie
Find the tan wire that goes to the vacuum switch on the port side of the mtr and disconnect that and run it. It could also be a bad switch. The switch is plumbed into the fuel lines.
BASSBOAT21
Banned
also ive read up on the check engine light and buzzer its caused by a vaccum---or restriction correct----funny after i changed this filter to a seasense unversial on this started happening --could this filter be to small of inlet and outlet to let the fuel go through like it should----it had plastic one on it--this type on there now is metal with glass see through with removable filter-----also as i was removing the filter the small line that hooks to the fuel line in a tee going into the pump came loose i put it back together it goes into a small valve like with two wires coming out of it hooked up to a plug--everythings hooked back up but could i have done something else not knowing ---taking guesses here but i dont see unit just going bad without any warning exspecially after ive done what i hae done which seems to be the root of the cause according to what iam reading--if i had not changed filter and this happened --yes i could think it might be a bad unit--possibilites?
daselbee
If it were me, I would remove the new filter completely for testing purposes. Simple enough.
