I have a 115hp outboard, and in a year I have had to replace the tilt/trim motor twice because it has developed a hairline crack in the plastic base that bolts to the pump. The first time I think it may have been a factory defect masked by the paint for a while, but the second time I bumped an under water stump at low speed that forced the motor up putting excess pressure on the hydraulic system causing another hairline crack, thus having to replace the little motor to the tune of about $170 and 4 hours work to pull the motor off the boat to get to the part.<br /><br />Has anybody else had this problem, and/or does anybody know of any aftermarket tilt/trim motors that are stronger than the plastic base this one is made of??
