2000 johnson oceanpro problem getting going
inxkn
I have a 2000 johnson oceanpro 90hp which starts like a dream and top end is great, but from idle in nutral to putting it in gear and giving it gas it stalls. It stalls 5 or 6 time then it suddenly works runs great anywhere above idle but when i power down to idle speed again it stalls and the process starts again. any ideas would be great.
Thanks
Haffiman
Re: 2000 johnson oceanpro problem getting going
Probably time for a carb AND throttle body clean and re-build. The idle and intermediate circuits are in the throttle bodies, however be sure the tubes in the carbs(behind the side cover) are not loose and leaking.
