Im having an issue with my outboard. It started with replacing a bad power pack and havent found the other bug yet. The motor will crank but runs on 2 cylinders (port side). We are getting spark to all cylinders, but the starboard side bank is not functioning. Any ideas? New plugs and wires, and also switched the coil packs from the other side with the same result. Compression tested at 150 at all cylinders. Any ideas??
