2000 johnson 30hp oil ratio
spudisland
Hey guys, I been getting different answers to what the proper fuel to oil mix ratio is, been all over the board.............came acrossed this forum and I figured it should be a better spot to ask, thanks, Jamie
Bob_VT
Re: 2000 johnson 30hp oil ratio
Welcome to iboats.
50:1 1 pint TCW 3 oil to 6 gallons of fresh gas.
pootnic
If your from P.E.I.(going from name)...just take the amount of liters(gas) times it by 20 and that will give you the amount of oil to add in ml's,at 50:1.
Lets say you have 15 liters of gas...15 x 20 = 300...so 300ml
You can also times by 2 and add a 0....
If your not using metric,I'm sure someone will chime in and help.
