This might be a long post so I'll short hand it. Put a used lower unit on and took it to two 8 hour bass tournaments ran good besides a notice in taking off, seemed like a little less power but ran top end speed of last lower unit. Gearing maybe or part of problem. My oil water 2 seals had to be changed due to oil leaking out. I just put 2 new seals in my last lower unit so I took the black housing out with the seals in it behind the prop. And switched it with my current lower unit so I didn't have to buy more seals. Took it out and it would start first turn and idle fine. Took off and rpm would not pass 1500. Went home and checked fuel lines then checked fire on plugs. Right bank all 3 not firin. Did research and saw something about the shift switch. I put a ohm meter on the black plug with the yellow and black or purple cant remember. It was reading weird so I just unplugged it and fired it up and the right bank fired. I read about it not coming out of foward gear with it unplugged. But my boat idles lower so I took it out to test it. Still my rpm didn't rise above 1500. Took cover off and right bank was firing. Do I need to put the black housing back in? It was all the same besides maybe the 2 pin bearings in it might have or looked kinda different. But I rammed it to 5500 rpm in neutral in the water. Didn't happen until I changed that seal housing. Do I check my power head or my coils? Do I sink it in the middle of the lake lol?
Thanks
andy
Thanks
andy
