Hi everyone, so this is a update from my first post. I have checked my compression,stator,timing and spark plugs. My shift switch interrupt is unplugged and still only getting 1500rpm max no matter if I'm 1/4 throttle or wot it stops at 1500 in the water in gear. https://forums.iboats.com/forum/eng...624699-2000-johnson-225-won-t-go-past-1500rpm is my first post. I haven't changed anything and I'm having more problems everyday. On the hose it started fine and idled fine didn't die this morning. About 2 hours of checking compression and checking carbs it started back firing and now dieing as soon as it drops from high idle to low. I unplugged the hose from fuel pump to carbs and it's a steady stream but not very forceful. I have 6 carbs and was manual giving gas and at around 1500 top right backfired/fired in carb. Noticed only a split second of my high idle jets spraying gas in 2 or 3 carbs then nothing then maybe another 2 shooting gas. Took fuel pump apart and looked very clean so maybe the electronics or not even fuel pump because I don't know. Won't idle now just dies and when manually giving gas backfires and tries to die at 1500 and some times I can baby it and get past 1500 and it works but I stop at 3k rpm.
