2000 Johnson 15hp where is idle adjust screw?
Jmac870
Anyone know where the idle adjustment screw is on a 2000 Johnson 15hp? This is only my second motor and the last one has a knob on the side you could use without removing the cowling. Anyways motor is quitting the odd time and sometimes sounding like it's starving for fuel while I leave it at an idle
oldcatamount
On the end if the throttle grip is the idle adjustment. Turn it clockwise to increase the idle speed.
Jmac870
Thanks! Kind of foolish but I thought that was just to tighten on when you hit perfect trolling speed
jrs_diesel
Yep, it's definitely not a friction lock.
Here's a tip because I had to adjust mine last summer. I was not able to get mine dialed in at all, it ran too slow and would stall. You only get about 4 full turns on that adjustment knob. I couldn't get mine to idle high enough (even after a link and sync). What I did was turn the knob to its midway position (two turns from a stop). You then have to pop the hood and find the cable linkage for the throttle, it uses a ball and socket style linkage. Pop the socket off of the ball and you can turn the socket end a few turns in and out (it's threaded) to give a better range on the adjustment knob. Turning the socket end out will increase the idle speed, turning it in will decrease it. Give it one turn at a time, snap the socket back on, and then start and test your new adjustments.
This should be done with the engine either on the water, or using a test barrel. Good luck!
