2000 Johnson 150
stevenburkhart
Over the 4th of July weekend, my motor showed signs it did not want to idle for more than 30 seconds. Later, during a severe wind & rain storm I let the motor run at 2000 RPM while moored to a bunch of other boats in case we had to cut the ropes and ride the storm out individually. <br />Several hours after the storm, I attempted to start the motor, but it was very rough and would only start if I engaged the throttle a little. Then it would run rough and quit after thirty seconds. After repeated attempts to start, it never fired again.<br />I pulled the fuel filter (which was still clean)and pumped the priming bulb and fuel was coming out fine. <br />I replaced the plugs with new ones, and it started in a similar fashion (with a little throttle), but only ran for 30 seconds and never restarted.<br />When I got home (finally), I tested the spark and only the top two plug wires were firing.<br />Could the lower two ignition coils be bad, or is it something else? :mad:
