Jose67
Thread starter- Joined
- Oct 5, 2016
- 50
That is what it sounds like. When I reached that RPM range it is like some circuit is cutting spark to the cylinders. I have tried disconnecting (one at a time) port side temp sensor, starboard temp sensor and shift switch all with the same result, can not get over 1,800 rpm. Does the shift switch activate when the button is pushed in or when the button is out? Looking at the shift linkage where the switch is mounted in it looks slightly curved and not straight. Maybe causing it to activate when it is not supposed to? I am going to try hooking up a spark tester or timing light and check each cylinder for spark at the RPM range that I start to experience the problem.
