I'm out of ideas on this one, need help bad. I recently purchased this boat and have had nothing but issues since. Boat compression checked out perfectly and ran great for about an hour the day I bought it. Second time out it bogged down and shook extremely bad @ around 1800 RPMs when leaving the ramp and has been doing so ever since. I can run it on the earmuffs and it will rev to around 2500-3000 for a short period (I haven't tried to hold it there out of the water). It also makes what sounds like a knocking sound when in gear at low speed. I can cruise around at idle without a problem. If I do not ease off the throttle while trying to get on plane it will stall out, but re-cranks without an issue.
So far I have checked/ replaced:
1. All six carb bowls were warped, replaced them all and did a carb kit on each.
2. Replaced all fuel lines including primer bulb.
3. Ran the motor off a separate gas tank and line system with brand new gas, same result.
4. Re-checked compression and spark- Perfect compression and spark on all 6 plugs.
5. Replaced Optical Sensor
6. Replaced Port Side Temperature Sensor
7. Replaced Power Pack
Side note- The VRO system has been cut off and plugged. It appears they did a good job plugging the line and cut the wires short enough that they shouldn't be causing an issue.
I have no idea where to go next.... any ideas?
