2000 Johnson 150 hp Trim/Tilt
sfmaster
Hi,
Today the trim/tilt was working fine. When I got home the motor did not go up. I switched relays (Has Two) both worked for the down direction. I guess that discarded the relay being bad. I released the pressure and raised the motor to check the fluid. It had fluid. Tighten the screw again. Now the motor won't go up and I can move the engine manually up and down after tighten the pressure relief screw what now ? Help please? Below is a small video I uploaded on YouTube.
Link: https://youtu.be/FCvthBbBvzU
Check the trim limit switch. If that became unplugged, when you were checking the trim sender, the motor might not be getting "up" trim power.
