2000 Johnson 150 horsepower Ocean Pro
Terry M Jones
I have a 2000 Johnson 150 horsepower Ocean Pro engine. It is a model number RJ150VX . I can not find a owners manual or any kind of info on the engine. I would like to know what is the recommended spark plug to put in the engine. I am having some issues and I thought the first step would be to put in new plugs. Does anyone have any information on the plug I should put in the engine?
ThomW
I believe for that motor you should only use the recommended Champion QL78YC. I am actually a NGK plug guy myself, but I believe that your motor will only work well with the recommended Champion plugs. Also, make sure you are using the grey inductive resister spark plug wires, or you may have running problems. Hope this helps. Here is a link to help you with any other questions regarding parts for that motor.
www. marineengine. com/parts/johnson-evinrude-parts.php?year=2000&hp=150&model=RJ150VXSSS
eandkatthebeach
I have a 2001 Johnson 150 RJ150VXSIF, agree w/ ThomW, Champion QL78YC, gap is .35, and first try an auto store, some carry em. much cheaper then a ?Marine store.
