2000 johnson 115 lack of spark.Power Pack ?
Wyndenwood
I have been having intermittent problem. At first I attributed it to a fuel issue as the right bank of cylinders fired fine.After cleaning the carbs the problem seemed resolved on the muffs.Today I put boat in the water to find out that nothing is better (Not able to get on plane) On the way back to the launch the motor shut off checked for spark to find total lack of it.After about 10 minitutes motor restarted an ran for about 3 minutes shut off again and again no spark. 10 minutes later it starts and runs for 3 minutes. Repeated the process about 6 times to make it back to the ramp. Power Pack ?
Wyndenwood
Re: 2000 johnson 115 lack of spark.Power Pack ?
My coil packs are on top or each other The top one supply's the two upper cylinders the bottom the lowers. My problem seemed to be on the right bank of cylinders.
