Engine has been running fine up until last week. Started missing a bit when cold on a trip last week, ran ok once warmed up. The last trip it was much worse, even when idling on ears in driveway, the miss was very pronounced. On the water it would be smooth for a few minutes, then start missing again. When it was running fine once at speed, I tapped the tilt/trim button on the shift control to adjust the trim and the engine sputtered. I repeated that 5-6 times again and each time the engine cut out when I tapped the button up or down. Loss of voltage ? Short in the shift stop circuit ? Boat is home now, started by removing both batteries and going to clean up all cable and battery connections. Dash volt meter was displaying 12.8 engine off, and 14.6 running on each battery side. I've downloaded the CDI troubleshooting guide for the 60* 4 cyl OIS. Interested in hearing what you might think, thanks.
