2000 johnson 115 electrical problem
jpatt12
The motor will run great for a few trips and then go dead. It will not run again for a few hours until it cools down. It will still crank and stay running as long as the key is in the start position but dies as soon as the key goes to the run position. I have changed the key switch and still having the same problen
Faztbullet
Power coil in stator or bad pack. Check connector into pack (orange wires) as seen them loose internally...
jakedaawg
You are going to need a manual, Multi-meter, peakreading voltmeter, amphenol jumper wires, amphenol pin tools. Lots of little tests that need to be done so that you dont end up throwing parts at it.
jakedaawg
Start with the basics. 1. compression test- this is to ensure that we are not throwing away a bunch of time on a dead motor.
2. spark test- make sure you are useing an air gap type tester that allows you to check spark from all cylinders at the same time preferably.
after these it will be time to break out the manual.
jpatt12
I have narrowed the problem down to the power coil on the stator but can't find the part online will I have to replace the stator or just the coil?
