2000 hyundai elantra acceleration questions
drewmitch44
I have a 2000 hyundai elantra which just recently started feeling like it does not want to accelerate like it used too. I know this is not a sports car by any means but I have had this car a long time and i can tell that something is not right. It happens when accelerating and the rpm's start to get up in each gear. It feels like im towing something heavy or something. It runs fine when up to speed and It is not that big of a problem but it is bugging me. I am pretty handy with doing maintenance on cars brakes, plugs, wires, cv boots, alternators and things like that. Im just worried that im running on 3 cylinders or something. If that were true would the car still run as well as it does? and how would I be able to test it? And what are some other things that could cause this? Any help would be appreciated! Thanks!!!
jtmarten
Master Chief Petty Officer
Re: 2000 hyundai elantra acceleration questions
Probably needs a good tune-up, injector cleaning, etc. If its dragging at higher RPMs, it could be a sign the catalytic converter is starting to get plugged.
drewmitch44
Hey that cat thing might be whats going on. Around the same time this problem started i noticed what i thought was a small exhaust leak up front before the cat conv. It sounded like the leak was under pressure, if i was ideling and i reved it a little it sounded like high pressure. If the cat is plugged up it would cause the car to feel like it was overloaded right? If it is having a hard time getting the exhaust pushed out? Also i found that if it was running on only 3 cylinders it would trigger the check engine light. THANKS jtmarten! how can i test the cat converter??
drewmitch44
anyone???
NYBo
A number of FWD cars have the cat right at the exhaust manifold. Yours is apparently one of them. A clogging cat would certainly kill performance, but it would likely trigger the "Check Engine" light before it got to that point. But perhaps the exhaust is clogged or crushed after the cat. An exhaust leak between the two oxygen sensors can affect the fuel/air mixture enough to cause performance problems too.
Autotech
DM44 is the the check engine light on. Do you use emergency brake on regular basis? Is it a manual trans? Reason I ask is I have seen the rear brakes stick or drag on some Hyundai's not on that model but on Excell, As well as clutch slipping on manual trans. both will effect acceleration. If Catatilic Converter is stopping up you can usually here it whistle from the tail pipe and probably set a code. I will read some TSB's on that model and get back to you.
puddle jumper
The best way to test a catalytic converter is with a temp gun. The temperature should be about 100 deg hotter coming out than where the exhaust comes in.
What Autotec said is what came to mind when I first read your post. Check you park brake operation. It may be sticking on.
642mx
If you think its the cat, pull the front O2 sensor and take it for a very short drive. Keep in mind your exhaust will be coming out of the hole for the O2 sensor and you will get a check engine light.... but if it runs properly (or better) than you can bet its the cat.
RogersJetboat454
Drew,
If the catalyst in your vehicle were ailing, it would most likely be setting a P0420 "Catalyst inefficiency Bank 1" code. Hyundai's are real good about running there non-continuous readiness monitors, so a bad converter would set that code fairly quickly. Converters also don't regularly plug up like the old days. If they do, its usually the result of a melt-down caused by misfiring cylinder(s). Misfiring cylinders would have quickly set the check engine light, and possibly made the check engine light flash if it was bad enough (flashing MIL means misfire I.E. your cat is being roasted).
If you are still worried about the health of your cat, the best way to check it is with a scan tool that supports live PID info. You would monitor bank 1 sensor 1 and bank 1 sensor 2 O2 sensors for inversions (voltage switching which mirrors each other) by graphing the voltage. Ideally you want bank 1 sensor 2 voltage to remain at a constant number (voltage should be as close to a flat line as possible when graphed) once the cat lights off. Checking the vehicles stored Mode 6 data for the catalyst monitor will tell you how good or bad the converter has tested during its readiness monitor test. The old heat gun test (measuring the rise in the catalyst shell temp VS exhaust piping temp) will tell you if the converter is working, but it won't tell you how well its working.
As a previous poster suggested, it may be worth your time to check the vehicle out for something dragging. An emergency brake cable or rear brake component that is stuck may be dragging the rear wheels. A front brake caliper that has seized will do the same. Is your vehicle a manual transmission? A slipping clutch can for obvious reasons cause a lack of acceleration. Whens the last time its had a tuneup? Restricted fuel and air filters will affect performance. If the air filter is particularly dirty, you may also find that the hot wires on the mass air flow meter (MAF) are covered in junk. Your vehicle utilizes the MAF as its main way of calculating fuel delivery per given load, so a not so clean one will mess with your vehicles fuel trims.
dockwrecker
Drew,
+1^^. CRC makes a cleaner especially for MAF sensors. CAREFULLY remove the MAF and spray it clean, don't try to just spray it off in place. DON'T touch the wires!! Works wonders, I do mine a couple times a year.
