Lizziejane
Thread starter- Joined
- Jul 21, 2008
- 5
These engines have been flawless for 900 hrs but about 20 hrs ago the stbd engine would start & idle OK, but not rev, in or out of gear to match the Port eng. After about 5 minutes at 1300 rpm (throttle had to be much further up on Stbd engine) The problem cleared and it ran fine all day. Both both engines run on same tank.
Had a independent, certified Yamaha mechanic do an annual in May, Plugs, Spin on & Water sep filters, water impellers. Coming back from the shop, Alarm sounded with good cooling stream visible, revs cut back on stbd Engine. I thought low fuel, or weed on intake, Let it sit and started up & ran OK back to slip (6 miles).
Happened again about 5 running hrs later. Cleared & ran fine 8 hours/offshore.
Refilled fuel tank, which had run low on last years fuel (used Stabil & Ring Free)
On the way back from fill up, Stbd engine would not rev. This did not clear this time. Mechanic is swamped and has not been able to get over to see boat at slip past 4 weeks (I have no trailer).
No water visible in filter.
I ordered parts for VST filter & downstream canister filter, all clamps and Diaprhram replacement for Low pressure fuel pump. Also Yam Diagnostic software. Per posts here I removed VST tanks. I have not put it back together yet, but the VST filter looked pretty clean to me. Not a spec in the VST tank after draining. Black crud came out the intake end of the canister filter. Hard to wash off hands.
Can anybody recommend anything else I should do/check/replace before reassembling? Can I check the pump in the VST tank with 12 volts across the red & blue leads safely?
Thanks!
Thanks!
